Sometimes, if I have too much time to myself, I think up crazy things. This time around, it's building a 3-channel Fisher EL84 amp (either 30A or SA16 3-channel clone). I have some OPTs from R20 mono chassis (and already know the optimal feedback loop for a 30A form-factor thanks to Dave), as well as a power transformer from an X-202. Based on some calculations I've done, it looks as if the PT will have sufficient HV current to handle (3) 12AX7 / 12DW7 and (6) EL84 / 7189 tubes. The heater tap will be insufficient for my purposes, but an Edcor 6.3V / 5A PT is pretty cheap. I'm assuming that I can simply build three channels, wire up the hum balance accordingly (heaters for the EL84s will be on the Edcor, 12AX7s will be on the X-202 PT), build the PT section as for a 2-channel amp and let 'er rip.
Please tell me in excruciating detail why my assumptions are wrong (before I waste a bunch of money and time), and this isn't as simple as I think it will be. :yes:
-D
p.s. I've even laid out the FPX template for the top of the amp...it's a sickness I tell you!!!
-D
