mjw21a
I ended up getting a Yaqin MC10T 3 months ago based on the many good reviews of the 10L, both on here and elsewhere on the net, marking my entry into tube audio. It powers some Sony SS-F6000P speakers (which I hope to replace with Bowers & Wilkins 683 S2's when i save enough).
The stock Shugang valves sounded great once burned in, with a particularly good 3D sound stage although perhaps a little rough sounding. Still great compared to my Denon SS amp though. I've done a bit of tube rolling since then and rolled the following tubes:
12AX7 spot:
Current production Shugang 12AX7 which came with the amp
Mullard Reissue
Tung Sol reissue
Electro Harmonix reissue
60's production Baldwin branded Matsushita 12AX7 Long Grey Plates - O getter
60's production Canadian Made Amperex Bugle Boys (Westinghouse branded)
'63 production RCA Grey Plates - O Getter
50's production Raytheon 12AX7 Long Black Plates
12AU7 spot:
Current production Shugang 12AU7 which came with the amp
'57 production Raytheon Black Plate 6414's
EL34 spot:
Current production Shugang EL34 which came with the amp
Current production Svetlana EL34b's
Current Production JJ 6CA7 "Fat Bottles"
Soviet era 6P3S-E "coin base" tubes
I still have some valves on the way to try, though the current setup already sounds so amazing that I can't really see how anything short of a new set of speakers can improve upon anything.
Valves on the way are:
50's production 12BZ7 Long Black Plates with D getter
Soviet production 6N2P-EV's + socket adaptors
The current configuration I'm running is as follows:
Raytheon 12AX7 Black Plates in the 12AX7 spot, Raytheon 6414's in the 12AU7 spot and Current production JJ 6CA7's in the EL34 spot. This seems to give an incredible amount of detail with nice even lows, mids and highs.
The JJ 6CA7's are scooped, or a little lacking in the mid range but with excellent lows and high's which made other tubes in the pre section with stronger mids sound particularly good without it being overpowering. I quite enjoyed the Matsushita's with these though the Raytheon Blackplates were noticeably more detailed without being an overpowering presence in the midrange. The Amperex Bugle Boys sounded similar to the Matsushita's.
The Raytheon 6414's were so good in the 12AU7 spot I didn't bother going looking at other tubes for this position and ordered more as spares. Nice and tight, low noise and good right through the range.
Mullard Reissue 12AX7 + Raytheon 6414's + Svetlana EL34b's were a nice detailed combination but seemed to lack the 3D stage / presence. Sounded more like a particularly nice recording (which it was) rather than actually being there in the audience. More detailed than the stock Shugangs but less 3D, still much better than my Denon SS amp though.
I did try the Soviet 6N3PS-E's and found them neutral and closed sounding, though to be perfectly honest I didn't even wait for them to warm up properly let alone burn in. It's just that the JJ 6CA7's sounded so amazing after burning in that I couldn't handle them. I'll give them another try down the track. My understanding is that they take some time to burn in.
I'm hoping that the 12BZ7's or 6N2P-EV's are as good or pretty close to the Raytheon 12AX7 Plack Plates once I try them. I only have the 1 pair of the Raytheon Black Plates, and they're quite expensive/hard to find compared to the other two. The 12BZ7's work out to $25 each and the 6N2P-EV's about $5 each so if they work well I'll stock up on them. I know the 12BZ7's are meant to be somewhat microphonic due to the long plates, though hoping some tube dampers will help with that.
Now to try supress the tube rolling bug which seems to keep biting me.... I need to save for better speakers dammit! :tongue:
Since getting this amp its caused me to listen to other types of music rather than just my usual 60's-90's rock. I'm finding country and jazz music sounds incredible. Listen through my Denon and its very "Meh, put something else on". Through the Yaqin its actually very interesting and easy to listen to music. Valves really bring out the detail of instrumentation far more than solid state. Wind instruments have a "breathiness" to the notes which I love, same goes for vocals. Go figure.
12AX7 spot:
Mullard Reissue
Tung Sol reissue
12AU7 spot:
EL34 spot:
