No - he was asking was DAC? if you used digital output, that is what you need.
I used the digital out from the player to the receiver for a few weeks, it was not an improvement. I have not used a converter.
I'm having difficulty justifying such an expense. Although CD mastering has improved from 16 to 24 bit, the CD's themselves are only capable of transmitting 16 bits. That's the max.
When video DVD's, in their various configurations, including many 'improved' digital schemes for music came to market, many of those are capable of transmitting 20 bits, I've been told some may be capable of 24 bit. Sadly, although there are some available, they did not proliferate either.
As an apples to apples comparison, my DVD copy of Led Zeppelin's Celebration Day sounds consdierably better than the CD version, sold in the same package. Most outboard DAC units can process 24/96 files (24 bits, 96K sampling rate). Many can process 24/192.
Bottom line, 16 bits is as good as CD's can transmit and the higher the mastering rate, the more compression they're going to exhibit.
Someone please explain to me what difference converting them would make? Unless it is the sort of difference I'm hearing from the 'high definition digital' in the new Satriani catalog, it's simply not worth the expense.
If the 'high definition digital' should proliferate, I'll be the first in line. Short of that, they're maxed.
Hmmm. What is the model of the receiver you used?
As for "converting"...digital audio is not very useful unless/until converted to analog. Hard to listen to otherwise.
As regards the apples to apples comparison you mentioned....I may be mistaken, but I don't think they are from the same master.
As regards the digital recording engineering process....generally, mixing and mastering is done at much higher bit rates (48 bits is quite common)...the additional dynamic range is very useful during these processes. Higher bit rates do not generate compression (neither file compression nor dynamic range compression).
this debate is moot. By that I do not mean to imply its not worthy, simply irrelevant. We hear what we hear. We like what we like. We appreciate our efforts (hopefully) in our hobby. The music that we enjoy is a product of synergy. Its an amalgam of factors whereas some are blatant and obvious to others that are sublime. We live in a world of resonances. The synergy that I reference play upon those resonances in ways that are incalculable. Think about the chain of events. From performance and the sound capturing devices used, mikes, amps, rooms, instruments, recording gear etc. To the mixing, mastering, tweaking, pressing and so on and so on and so on. Forward to the listening, players, amps, cabling, rooms, speakers. Forward to the perceptions, age of listener, angle of head, mood, expectations, room, furnishings, the humanity. Every tiny step along this path has its own evolutionary science built around it. Its not about vinyl or cd, its not about digital or analog. Its not about money or equipment or the size of a collection. Its about sound. A unique human magical trait that we all share as a hobby. At my age, even after all the abuses, im so grateful to be able to hear. I still hear pretty high and pretty low and I still would rather be dead than deaf. Theres a church nearby that has a real bell atop. Whenever that bell is ringing, I stop in my tracks and am absolutely transfixed at the sound. Its purity makes it totally magical, the world stops for me, I get choked up, Absolutely breathtaking. I am so grateful for that gift. My sound system has evolved and upgraded and is measurably in the highest percentiles (just as many of you have also) and many recordings give me great pleasures to listen to, but to hear a real bell, a real voice, real sibilance, real thunder. Music is majesty. All the developers of all this technology for all time do what they do to bring us ever closer, but none of it is REAL. Its all moot! A hundred million combinations, and a hundred million opinions of each. You all do the math. All the conversations about bitrate and Pink Floyd and bose 901s .. Audio Karma my eye!
Listening to vintage gear means sometimes to be ready to compromise a bit...
So the first CD Players are olld junk, right? :sigh:
That is what I was saying but I think digital outs were only really high end - the Denon DCD-820 had it and that was high in the line (as an example).
Not all of them. Some from early 1990s were good. Those which used PCM63 DAC chips and discrete I/V converters are mostly competitive with today's best units in pure Redbook playback. But these were generally top of the line devices from few brands - which we now call high-end. Common mid-range players were much worse than today's mainstream equivalents.Everyone has an opinion, of course....but there are certainly some upper-end CD players from the late 80's and 90's that sound pretty good (at least to me). But by and large, the technology has definitely improved. Personally, I think the way to go is to get an outboard DAC. This gives you the opportunity to take advantage of these technology improvements (the vast majority of which have been in the conversion and op amp functions, vs the transport/reading functions), and gives you the ability to use it for both CDs and data files (streaming, hard drive, media server, etc). Of course, you still need a CD player for the transport and read functions...one with digital out capabilities for connection to a DAC.
