Zonker92
All shiny and chrome
I use CAIG DeoxIT D5S-6 (although I'm not an expert on all the DeoxIT options; it's just the one I happened to pick). Lying on my back, I stick my head into the woofer hole looking upward, and from there it's easy to see the pots with a flashlight. The rheostat for the HF is exposed so you can spray the wiper and element directly. The L pad has a cover but it has vent holes that let you spray into it using the tube that comes with the spray can.
I give them both a good hosing down and then use the flat end of a plastic pry bar (for working on car stereos) to rotate each control knob a few dozen times; cleans them up nicely.
If you look here at page 5, figures 7 and 8, you can see what they do (on a 4430). I have read that it is best to set them both flat, then set the mid control to taste, then finally the HF.
