Sam -- If you can point me to a schematic for the FM-200, I'll take a look. Right off hand, I didn't see one readily available. Knowing Fisher however, the B version was likely primarily an effort to update the unit to include its own MPX decoder, with only minor changes in features to accommodate that change.
Hunter -- The 100C is a good tuner, but was clearly manufactured during changing times at Fisher. As Larry mentioned, a SS MPX decoder is used. I've never seen one, but looking at the schematic, it appears to operate on the exact same principle as their time switching vacuum tube decoders work on, so I would expect performance to be very similar. They also use SS switching for the Stereo Lamp as well. Additionally, they have eliminated one IF stage in the C (down to four), and while they made up for the lost gain by using the high performance 6HR6 in the first stage, it is still the loss of one tuned circuit from a selectivity standpoint. Finally, it also appears that they went to using nuvistor tubes in the front end of the C version as well. All in all, it should still be a very fine performer.
General -- As Don and Larry pointed out, they can hardly tell the difference between their stand alone tuners, and those included in their receivers. There's a reason for this.
Understand that the primary difference between the best stand alone Fisher tuners and those in their receivers is: (A) selectivity, and (B) noise limiting capability. NOT sensitivity. More to the point, the better tuners will show themselves in large urban areas where numerous stations can cause crowding which makes improved selectivity helpful, and in very rural areas where lower signal strength levels still allow full limiting action to take place which minimizes noise and static.
As a salient point then, once ANY FM tuner has properly captured a signal and driven the last limiter stage into full limiting, then the recovered audio quality will be identical from all of them. The improvements of the standalone tuners then are all about "reception" quality -- not the recovered audio quality. That is determined by the standards and caliber of the station tuned in.
Finally, since at any point in time, Fisher basically used the same MPX decoder in all of their production models, then the FM Stereo audio quality of from any Fisher FM Stereo tuner section will be virtually identical as well.
This explains why unless you live in a very congested signal area with numerous strong signals, or a very weak rural area, you almost surely won't notice the difference between the various tuner models and designs. Remember, these units were designed and built at a time when Broadcast Radio and TV were IT. There was no Internet or Satellite TV, and cable TV was something that was only used in large apartment complexes or high rises, where a multitude of antenna arrays were impractical. Therefore, building the best tuners to offer the best reception under the worst of reception conditions had a strong following, as the various tuner offerings of Fisher documents. Today however, most of the reception benefits of the better tuners are lost on the degradation of audio signal transmitted.
I hope this helps!
Dave
