DixieMan1994
Hey guys,
Got my caps in from mouser, so I started the recap on my 737. Everything went fine (I started on the power supply board) until in my infinite wisdom failed to make a proper soldering joint on one of the caps (the 50v 220uf cap in the middle of the board). I went to fire the unit up and ZAP, there goes the screw in 3A fuse mounted in the back panel :dammit: :sigh: So once I solder up a proper connection with a small jumper wire, where could I get said fuse?:worried:
