jasoncauthron
I recently acquired a KR-6050 receiver. I've always liked the looks of this series. The one I found was extremely dirty, lights out, peeling laminate, dirty pots, and chewed-up power cord-- but it was functional and cheap. Popped the hood and looked around inside and powered it up with a light bulb in series long enough to verify that it was a good candidate for restoration. The power switch was sizzling, and there were a couple of caps that didn't look too happy, so I ordered up some replacement electrolytics and one of the "Alternistor" triacs, and some other misc. parts.
Long story shorter, I recapped most everything except some of the tuner board, adjusted bias and offset, got everything back together and amp works great EXCEPT that -on the left channel only- when I turn either of the tone knobs, I get a little popping noise as the offset jumps around. If I switch on the subsonic filter, I get about .5V offset (I think it's negative relative to speaker polarity, if I've got the leads on + to + and - to -). When the tone circuit is set to flat, everything is fine, and the right channel is fine anyway. Engaging anything in the tone circuit does cause small changes in DC on the right channel, but small being +/- 10mv, I consider to be normal.
I'll try to attach a readable picture of the relevant portion of the schematic.
I changed the 2.2mF coupling caps C7/C8 to Wima film, and I also used film caps for C9/10, C11/C12, and C15/C16. After discovering this problem, I swapped channels with C19/C20 which made no difference. I swapped Q1/Q3 with Q2/Q4 and problem stayed with the left channel. I also changed out Q5 and Q7 with no effect. I've checked or swapped channels with most of the parts in the tone circuit and can't find anything that makes any difference. Does anyone have any ideas on what might be causing this? I'm running out of ideas and would really like to get this thing buttoned back up because I've got it looking really nice! I'll try to attach picture later.
