brainbanger
Member
Hi guys,
protection board issue fixed, next problem showing up: the right channel is dead on FM Stereo only, Mono and all other sources work ok.
Measured FM Output on Pins 17 + 19 on the Tuner Assy AWE-040 with a scope. While tuned to a stero FM Station (stereo indicator on), Pin 19 (left out) delivers a signal, Pin 17 (right out) is dead.
Checked & compared Q9 and Q10, as well as Q7 and Q8. All voltage readings match the SM. Also, IC HA1156 matches all readings against SM.
I am stuck because my limited knowledge is not sufficient to identify the signal path on the board to track the error down. Anyone able to help me? Eyes, ears, DMM, scope and an open minded "50+" brain available
Regards,
Andreas
Regards,
Andreas
