Read this:
http://www.audiokarma.org/forums/showthread.php?t=614045
Mark will probably have you work from this example.
Will do!
Thanks for the link Mr. Las Vegas aka Zebulon.
Read this:
Will do!
That resistor R8 resides in the area where the cracks usually occur.
Dang, didn't want to hear that! I'll double check the board looking for those darn cracks.. @j@
Troubleshooting a hum is time consuming. Good job so far!
So no hum when you were checking the resistor (R8) on the power supply? Please explain that a little better.
I have a 1010 here, so if you need a visual reference I can pull it out easily.
Flu better?
Try successively shorting backwards the stages at the inputs, if the hum goes away when an input is shorted to it's ground reference, we know from the short forward the chain is blameless. This is what I would do, with a LOT of added study as to the shorting points to interrupt the signal.
Just went through and read this thread. Wow, sounds like a real nightmare! I'm about to rip into mine... and am getting a bit apprehensive about even starting! :0
tax man here too, for more than myself. plus voting screw-up for tomorrow's election (missing absentee ballot, too late for early voting etc) - the line of pains in my @## grows longer every day. sigh
