They actually did something smart in that amplifier - the 220 ohm idle current adjust pot has a 330 ohm resistor across it, so if the pot opens up the amp doesn't self destruct, so there is hope.
Now, why the pot would self-destruct is another matter, let's hope the stv-3h survived.... (it's on the opposite side of the heat sink)
If you do it yourself, it will be a few bucks to replace all of the transistor in that channel, 6 bucks for shipping, and some time.
You will need soldering equipment and a DMM.
Posting a picture of the destroyed component composed like your first picture would be great... don't need the "paint" add on....
2sa725's are known to fail....
transistor replacements:
2sa725 ecb 35v 0.1a 0.2w 500hfe 100mhz
512-KSA992FBU (ln)to-92 ecb 120v .05a .5w 100mhz 150-800hfe $0.05 ea
2sa720 / 2sc1318 ecb 60v 0.5a 0.625w 85-240hfe 200mhz
512-KSA916YTA_Q TO-92L ecb 120v .8a .9w 120mhz 60-240hfe $0.05 ea
512-KSC2316YTA_Q TO-92L ecb 120v .8a .9w 120mhz 60-240hfe $0.05 ea
2sc789 bce 70v 4a 30w 40-240hfe 3mhz
512-KSD526Y npn to-220 bce 80v 4a 30w 3mhz 15-240hfe $0.62 ea
edit: adding capacitors, one board's worth - need x2 for whole unit
c1,c2 1uf 25v cssa 1uf 50v 667-ECQ-V1H105JL $0.38 ea
c7,c8 220uf 25v cea 220uf 25v 647-UPW1E221MPD $0.28 ea
c19,c20 2200uf 25v cea 2200uf 25v 647-UPW1E222MHD $1.12 ea
c21,c22 2.2uf 50v cea 2.2uf 50v 647-UPW1H2R2MDD $0.14
c23 100uf 50v cea 100uf 50v 647-UHE1H101MPD $0.29 ea
c24 220uf 35v cea 220uf 50v 647-UPW1H221MPD $0.44 ea
looking for the pot... horizontal mount/adjust is the complicating factor
don't order till I say ok, we have to find any other destroyed parts.
