Leokarma
Well-Known Member
I recently got a Pioneer 1280 and seller said that it doesn't work. I need your help to troubleshoot the problem if possible or else I'll give it to a professional for repair. So far I have done following:
1) Connected via dim bulb tester and the receiver turned ON like it should i.e it Turned on (all lights) and after 8~10 sec. the trip clicked. No fumes, no small, no problem.
2) I connected the receiver without dim bulb tested and the receiver turned ON and after 8~10 sec. the trip clicked exactly how it's supposed to. No smell, no fumes, no problem so far.
No further testing was done or speaker connected because I'm scared. That's where I need your help. What should be my next step or sequence of steps to test this receiver ? Can someone help ?
Can I connect the speaker and test ? Should I test DC voltage across speaker terminal ? Check for fuse etc ??
