Decibel_116
AK Subscriber
So here is a friend's Technics SL-Q2. He asked me to "fix" it for him. His complaint was the cueing wasn't lifting high enough. As you can see in the photos, the tonearm is actually bent downward about 10 degrees from the tonearm rest forward. Something heavy must have been stored on it or maybe it took a good whack from someone losing their patience. Whatever the case, I need some suggestions on repairing this. Should I hold pressure down on the tonearm at the rest and pull straight up? OR, should I go out in the garage and get a sledgehammer and finish the job?
Thanks for any inputs.
Cheers,
David
Cheers,
David
