smitkoku
So I need to rewire this arm. The wires broke on a couple occasions, and now it is just time to replace them. BUT..... I can't figure out for the life of me how to do it. I've taken the arm apart easily enough. But the wires run to a connector at the very back, which I have photographed. I can't figure out how you can replace the wires. I've tried to take off the back where the wires connect. I pulled out the wires, but the copper pins stayed in the white plastic piece. To make matters worse, I'm not sure which color wire goes into which connector. It looks a little like a DIN connection, but the pin positioning are different. I have the service manual, it says nothing about rewiring the arm. I've searched through all the forums here, as well as vinyl engine to no avail. Can anyone help me out? I don't want to have to find a new arm.... :thumbsdn:
