invalidbuffa
Does anyone know where I can find the fuse-style lamps for a fisher 400?
edit: Nevermind, I fixed them!
When I removed the bulbs from the unit the metal bases came undone from the lamp, but upon inspection the filaments were intact. I scraped out the dry glue and pooled some solder in the bottom, and while heated inserted the bulb into the base so the solder bonded to the wire. I then very carefully put the bulbs back in and voila!
