Hi all,
I just got a pair Kenwood L-07M( one with 3 pair PT Sanken 2SA747A/2SC1116A) and one with 3 PT: Marantz A747A and 3 Sanken 2SC1116A) and tried to re-cap it.
After powering it up using DBT i plug both direct to the 110V source both pieces come out of protection successfully then i can adjust one piece(with all Sanken PT) for power supply voltage for differerntial amp , DC offset and bias as recommended by Kenwood
But by other piece i only can reach to 57V for power supply voltage for diff. amp ( vs. reference: 63V) and not further. Exhange the VRf1 1K from Bourns does not help.
I have checked all components of the power connection board and do not find any unnormality.
I have measured following:
By Qf1 (2SC1669):
C (for B+) : + 84,5V instead of 87V
B: 57.3V
E: 56,6V
By Qf2 (2SA839)
C (for B+) : - 84,5V instead of 87V
B: -72.8V
E: -72.2 V
Rf1/2: 4.7K
R17: 56K
R21: 4.3K
Suspected defect Qf3/4(2SA850/2SC1735) I replaced it with new KSA1220YBUKSC2690AYBU but change with same voltages at Qf1/2 and power supply voltage for differential amp.
I have measured the voltage at zener diodes :
Df1(YZ-140): around 14V almost same as in service manual
Df2(YZ-140): around 14.6V a bit higher
Df7(EQA01-5S): around 5.2V
All are good with diode test
Checking Qf1/2(2SC1669/2SA839) , Qf5/6(2SC1213A/2SA673A) with diode testing mode they are OK.
Nevertheness with acceptance of the highest voltage I can get 56V i was able to adjust DC offset to around 0.0mV and and bias to 25mV
After power it off and 30 minutes later i powered it up again to re-check DC offset & bias but this time the protection relay does not come out. Checking the power amp I found one driver transistor Qe11(2SC1913) was shorted (B-C).
Checking all power transistors( 3 Marantz A747A/ 3 Sanken 2SC1116A) with diode test and they still are OK
Currently I took this power board out and will replace the driver transistor pair (original 2SA913/2SC1913) through 2SA1837/2SC4793.
Without power amp board plugged i tried to power it up the relay does come out of protection but I got same voltage results as before.
Measured the voltages at RC4558T with following results:
Pin 1: 2.13V (Opamp output A- should be 3.7 V)
Pin 2: 5.06 V (Opamp in put A- should be 4.5V)
Pin 3: 5.06V (Opamp input A - should be - 4.5V)
Pin 4: -14.7 V (should be -14.5V)
Pin 5: 0 V
Pin 6: 0 V
Pin 7: - 3.97 V (Opamp output A- should be -3.7 V)
Pin 8: 14.22 V(should be 14.5 V)
So my questions someone can chime in what will cause this problem so that i can not adjust the power supply voltage for differential amp to the spec.( only from 52 V to 56.6 V as maximal vlaue and no further to the reference 63V)?
1. My first doubt: Maybe the IC RC4558T is defect? And its replacement JRC 4558D with modified pinout ?
2. I also suspect the control transistors Qf1/Qf2 (2SC1669/2SA839) for the cause due to aging?
What should I replace for this pair for best result for examples MJE 15032/15033G( but low Hfe compared to the original 2SA839/2SC1669)?
3. Other possibilities like ?
Thanks
By Qf1 (2SC1669):
B: 57.3V
E: 56,6V
By Qf2 (2SA839)
B: -72.8V
E: -72.2 V
Rf1/2: 4.7K
R17: 56K
R21: 4.3K
Pin 5: 0 V
Pin 6: 0 V
Thanks
