Looking to build a simple 2 channel system. Can the DAC-11 be run straight to a power amp like an Emotiva UPA-200 through the tube output? Aside from having to walk over to the unit and adjust the volume on the DAC, would there be any other problems?
Would it be better to run it through an integrated like the Yamaha as500 or the HK 3490? Either way, the power amp or integrated amp will just amplify the signal/sound coming from the DAC-11 without any further processing, right?
