I have found a slight difference between channels. The voltage at the input is the same on both channels (measured just before the volume pot), but at low levels, one channel has a few millivolts more than the other. At maximum level, both signals are ok. I can adjust the gain of each channel independently, but if I match the levels at low voltages, then they are mismatched at maximum level (I think that due to the feedback of the “varigain” topology).
