Karl vd Berg
Hi all,
Today I got an AX-550 RS for what (I believed) a reasonable price of 60 EUR (it was priced 65, but the guy left it for 60).
It's my fisrt Yamaha. I have a Sansui AU-317 (recapped here) that cost me 25 EUR, and an Onkyo TX-84 receiver (20 EUR).
It's in really good condition and quite clean also inside. The previous owner left it in the closet for about 2 years as he got a Sony TA-FA3ES since then.
I was always curious to try an Yamaha unit and this just came across as we are some 200m "neighbours".
Anyway, I took the unit inside, opened it to see if everything was ok. I discovered that one of the pins of the left main power cap (12,000uF) had a broken solder point. Quickly I heat the iron and fix it and did another overview, everything looked nice.
Turn it on, waited some 15 minutes before start checking for bias adjustments (10mV). It was 4.6mV in one channel and 14,3mV in the other. After some 15 mins. I put the values according to the MS to the 10mV.
I noticed the values rised up to roughly 10.4mV every 5 minutes. Waited about half an hour and adjusted it again to 9.9mV both channels and waited another 10 minutes. Reached the 10mV and stayed there. Unit closed.
I liked the way it is made, not messy at all, no flexy cables across the board, seems pretty easy to service. And the parts, even for an average unit like this, seem well selected. This is an amplifier manufactured between 1991 and 1993, so maybe more than 20 years ago. Street price in the EU countries seemed to be around $420.00 in 1992.
The AX-550 RS presents good numbers: 85Wpc RMS, 0.005% of THD, 110dB S/N ratio, higher than the 100dB S/N the Sansui AU-317 has and more powerful.
However...
... the Sansui sounds much better to my ears. Maybe I have to get used to the Natural (flat?) Sound of Yamaha amps. Or maybe the full recap I did on the AU-317 is making some difference, I don't know... But I expected more from this unit... After one hour of listening, the amp appears tired, lifeless, without any dynamics and... not clear at all!
Seems even showing some little distortion, but I'm not sure...
Even the Onkyo TX-84 receiver sounds better than the AX-550 RS...
I'll leave running for a few days to see if I change perception of its sound...
However...
