Two years ago I purchased a Garrard 40b. Not a great deck but it was the first real turntable that I ever had years ago, and I wanted one for nostalgia. When I got it home, the record size selector didn't work (it thought everything was a 7" record) and it would slow down and nearly stop while cycling. I knew it was the grease/glue that Garrards are famous for but never tore it down (I don't really know how) and it got shoved in the attic. There is no heat or ac up there and the temperature change is extreme in summer and winter. I pulled it out tonight because I want to use it for 78s and figured it could be used in manual mode. I wiped off the layer of grime and plugged it in with a junk lp to see what would happen. To my surprise, it started right up and seems to have fixed itself! The size selector is working perfectly and gently dropping the arm where it should and the cycle is running smoothly without slowing a bit! The only issue it is having is the stacking spindle won't drop the record. It seems to be a little gummy. I figure a good soak in alcohol should free it up. I put the short spindle on and it's working perfectly. A new 78 stylus for it's Pickering V15 and I'll have a decent 78 deck. So I guess the easy solution to Garrard grease syndrome is to let it get very dirty and expose it to extreme temperature change. Not really, but it seems to have worked!
