Hi all
I recently purchased a Thorens TD-145 mkII which is my first foray into the world of turntables and vinyl. So far I'm enjoying the experience, however I am finding the Thorens a bit of work. I have enjoyed modding so far, although I haven't gone too far with the unit. I have replaced the base with 16mm MDF, replaced the stock feet, replaced the power cable, and added some newer RCA cables.
I am having some humming/buzzing coming through the speakers, and these noises come and go depending on the position of the tonearm and other factors which I couldn't quite nail down so I decided to add an external ground wire as per the service manual. The hum got worst until I eventually found a ground strap attached to the left channel (blue pin) of my Stanton 681eee cartridge. So with this removed, the noise on the TD145 is at a level that I am very happy with.
That is until I turn the motor on. I get a buzz through the left speaker, that is usually faint, but not always. This buzz does get loader as I move the arm to the centre of the deck (or towards the motor in other words). When I tap the cartridge or tone arm it sounds just like tapping a microphone (the noises come through the speakers) - is this normal?
I have the earth running to my Rega A2D phono stage, but I also get the same noises if I run through my Sony ES amp phono stage. I have checked the pins on the cartridge to make sure they are tight, and the stylus is firm on the cartridge. When I remove the wand (I have a TP62) I get a loud hum, not sure if that is normal either.
Any help with this would be greatly appreciated as I have searched the forum and I am now lost!
