Thank you for looking at the schematic for me.
There is a light diffuser box mounted behind the LCD where a bulb can be mounted inside of a silicon grommet. That is where a retrofit bulb was mounted but had burned out. It was not a perfect fit and was spliced in with electrical tape.
I found a 12V 60mA bulb at the shack that works for the time being although a little dim. I can see the display functions now and all is working great. As I understand it, these displays were dark to begin with so maybe I'm in the ballpark already.
Still would like to know what the original spec for the light is.
Thanks again.
