I have a Pioneer TX-8800II which in the USA is a TX-8500II.
THE DOUBTING FACTOR:
Some years ago I had another TX-8800II. I replaced all the caps on it and cleaned up the board. It was great — the sound improved and all. Then a couple of years later it died — just went dead. I inspected it as much as time would permit. We were moving house, and I had a ton of audio gear piled up — gear that like the TX was bought as junk. Some worked some didn't. Well, I thought it was either a chip death or dodgy transistor. I had no time, no space — so it went to the place where it might have gone anyway before I bought it. Bye-bye!
Onto my spare TX ... same model. Now I am being very cautious before I commit all the time it takes to re-cap and fiddle. I have caps to do the power supply. But before that I wanted to check out why I was not getting lamps for "WIDE" and "STEREO". I pulled the lamps. NARROW looked OK and it lit up when toggled. Under a loupe the WIDE build was obviously open. And I thought I could hear a difference between the two settings. Well ... OK ... who really needs the lamp?
QUESTION: Why does the NARROW lamp only work when its plugged into it's rubber retainer? There is no circuit in there AFAIK ... and there is no exposed part for say, DC to ground.
Now the STEREO lamp. I pulled it, and it looked good. But why no light? With the circuit on I put it back in and then pulled it again. Then under the loupe it appeared to have gone open. Apparently these lamps are fragile.
The question nagged me — why did a former OK looking lamp not light?
So ... onto to STEREO. The lamp looked good but was not lighting up. So, next ... I put the meter on the leads and got voltage on BOTH mono and stereo settings. I assumed that on mono it would fall to minimum or zero! But no ....!
Then — out to the garage and my parts bins. I found a bulb from some old tuner. I tried soldering it on the STEREO leads but one of them broke away from the bulb.
Well ... if I really have WIDE and STEREO, I can live without the lamps. But the questions.
* How can these lamps light up only when plugged in — or is there a quirk?
* Why is there seemingly comparable voltage both in mono and stereo toggle positions
* What is the usual way we can replace these — diodes? And do we need resistors in series with the diode? What diode?
* Have I got a problem?
I feel kinda stupid. I should have some answers myself. I used the search engine here — but I am stuck.
PS: This unit probably cost me only 5 or 10 bucks here in Japan about 10 years ago. I could junk it if it is suspect, but it sounds pretty good as is.
I sure could use some guidance here ... thanks in advance
