kevzep
Its all about the Music
Yep, so I found one for a good price which was only 2months old in California.
I am naturally crapping myself as it makes its way here from California, praying it will arrive undamaged......
I learned that the C48 voltage settings not able to be changed in the field, it involves changing the transformer.
So I am stuck with it in 120V. But that's OK I have a couple of nice step down transformers, one of which I use to run the C48.
So with this the system is complete......but I will be working on refining the bedroom system, as I had to sell the MC352 to buy the C48......
I think I might get a period amp to match the C40, maybe a MC7300 or possibly a MC7270......
To do this I will move the C32 and MC2205, I already have a buyer lined up.....
Well, exciting times ahead, and I can't wait to report on the C48 performance......
from the owners manual
Power Requirements
Field AC Voltage conversion of the C48 is not possible. The C48 is factory configured for one of the following AC Voltages:
100 Volts, 50/60Hz at 30 watts
110 Volts, 50/60Hz at 30 watts
120 Volts, 50/60Hz at 30 watts
220 Volts, 50/60Hz at 30 watts
230 Volts, 50/60Hz at 30 watts
240 Volts, 50/60Hz at 30 watts
Standby Power, less than 0.5 watts
Note: Refer to the rear panel of the C48 for the correct voltage.
