I restored my MX110z just last week, though mine was already working fine but hummed just a hair when cranked. I pulled out the seleniums in the bridge configuration and screwed down two 5 terminal strips. I then wired up 4 silicon diodes. I replaced the two main PS caps using 50-50-50-50 cans from AES. The large can for the DC filament supply isn't available as far as I found, so I mounted a terminal strip there (leaving the original cap mounted for looks) and wired up two smaller caps and disconnected the can + wires. I then replaced the other smaller electrolytics. Sounds great, a little more clarity, and no worries. I found good pics on this forum that helped with the diode redo, and I got it all done in one evening albeit a long one. At some point I'll bring it to Terry for an FM alignment, though the FM section is working pretty nice already.
