Pioneer!
Picked up a Kenwood KA-8300 amp up the other day with a burnt out switch for $10, quickly had the switch jerry-rigged and it's working very well. I do need to locate lamps that backlight the output meters. The current bulbs are the following:
Stanley 8.0V 300mA mini lamp, has part number S86 on it with a rubber base, here is a picture
Here
Sorry, I didn't want to fill up your entire screen so I put a link to it.
If there is an equivalent available somewhere, I would greatly appreciate it if someone could point me in the right direction. If possible I can install some wedge lamp sockets that will fit in the holes and purchase matching-spec wedge lamps. I haven't had a ton of luck finding rubber base lamps with the same specs.
Here
