Need a new headshell for the Kleos cartridge. Am wondering if there is any 'real' difference between Mg or Al? Options thus far are Ortofon, Sumiko & Nagaoka.
Need a new headshell for Kleos. Am wondering if there is any 'real' difference between Mg or Al? Options thus far are Ortofon, Sumiko & Nagaoka.
Seems all the 'better' AT headshells have blind screw holes from the bottom like the one that came with my AT33R (Japan, only) cartridge. As the Kleos has threaded mounting holes the headshell needs to have through-holes rather than tapped.And you forgot Audio-Technica as well.
Not for me, thanks. Cleaning LPs, swapping out gear and the occasional repair is enough. I'm a competitive shooter and loading my ammo keeps me busy with its exacting requirements. When I'm through with this mornings e-mails I'll be casting a couple of hundred bullets. After that I'll only have ~1500 more to cast, which should carry me through the majority of the 2015 season.Many DIY headshells from wood(s) and even metals. They can be V easy to make..Not exactly a complex item Might even find it as a fun exercise?
Magnesium is significantly lighter than aluminum but I think that most "magnesium" headshells are really Mg/Al alloys.
All of them are alloys - pure magnesium is too unstable to use for just about everything. I seem to remember that science teachers like demonstrating the violence of the reaction when pure magnesium is exposed to air!
Magnesium will burn, but won't spontaneously ignite at room temperature. I keep some magnesium ribbon around to burn, it's really bright.
I am supremely happy with the exotic wood headshell I just got - it's Ortfon's near TOTL
LH-8000. I wasn't prepared for it to make as much difference as it did over the stock Al headshell (From a PX-2) that I was using.
http://ortofon.com/hifi/products/headshells
Worth a serious look...
jblnut
I really like the adjustable azimuth feature on my Sumikos.
boreas' point about effect on tonearm mass is worth noting. Sometimes one does not want lighter...
Drat........... why did you have to post this?Have a look at the Yamamoto Onkyou HS-3 Headshell (Boxwood) just under 90.00 US.
http://betterhomeentertainment.com/s-home/bhe/yamamoto-headshell
Am going to have to spring for one of those carbon fiber or Ti headshells for the Kleos and use the Jelco for the Kontrapunkt-b. Have to do a bit of research to see which is the proper one (must have 6 or 8 in each material). Great selection. Thanks.
