eedork
I picked up a non-functioning CR-800 today for almost nothing. It is in wonderful cosmetic condition, but is stuck in protection mode. It powers on but the relay does not engage and the tuner seems to be non-functioning as well. I am unable to get either meter to deflect at all while moving through the FM range. AM is also non-functional.
I've cleaned and applied De-Oxit to all controls including the coupler switch. I adjusted bias and balance as per the service manual. The fuses are all good. The output transistors show no gross faults (I did a real quick test). Tapping the relay does not cause it to engage.
I was hoping it was going to be one of the easy things I've already tried .. I'll have to dig deeper and verify that correct voltages are getting to all boards.
Is it possible that the protection mode and non-functioning tuner are due to the underlying issue?
-Matt
-Matt
