I just acquired a CR-620 and it works quite well and with the original working lights too. But when on the Tape 1 or Tape 2 input selector the audio will sound distorted/crackly on the right channel unless I wiggle the control a bit and then it will sound perfect. It always works perfectly on the AUX, even if I wiggle...I have not tried the other inputs yet.
As most know there is an branch/arm going from the switch to the mechanism, which is further back in the unit. I sprayed quite a bit of DeoxIT on the input mechanism, as well as the record too. I also sprayed the inputs (inside) at the rear.
Unfortunately it still does this, and I put quite a bit in too. I'm assuming that I shouldn't need to spay where the switch is, since it's just a arm that is connected to it and nothing more. Right?
Thanks!
Thanks!
