4seatPilot
"Broker"
Ok - I've done my due dilligence and searched, to no avail. Either I'm doing something wrong (quite possible) or nobody has posted a replacement relay suggestion for this receiver yet.
I've got a few units opened up for re-furb, and figure replace all the relays while I'm at it. I've found that as far as I can tell, the CR-820, 1020, 2020 and maybe the 620 too, all have the same relay - MY2N-DC12 Omron or HC2-HP-DC12V Panasonic. I haven't looked at the 3020 relays yet.
(If those aren't right, correct me and I'll adjust the post as to not lead anyone astray)
I found this G2RL-2A-DC24 for the A-1020 integrated amp...
But I have not been able to locate one to fit the CR-840 - and presumably some of the other n40 units too. The one from the 840 that I've pulled out is a DEC Type MS4U 12VDC according to the markings on top. It has a different pin layout than the n20 series, 4 across one row, two other rows with just the outside 2 pins in each row. I can take a pic if needed - but I'm hoping somebody has the part number recorded and can just post it.
