amr2
Well-Known Member
Hello
I have been adjusting the bias on a (repaired) Yamaha M80. I have realised that one channel has an oscillation at the output (sine waveform, about 1Vpp at 500 KHz) with no load, and before biasing it (pure class B). It happens occasionally, but when it happens if I start to bias the channel, it disappears quickly. Once biased, seems that this oscillation is not present anymore.
Output transistors are 2SC3858/2SA1494 (Digikey)
Should I worry about this? What kind of test could I do to check stability?
Thank you.
Thank you.
