The varactors fail with age, so replacing with other used ones won't work. If you can't find new old stock, you have to find the datasheet for the originals and then find new diodes with the same or similar pF/Volt slope and range. Unfortunately most, if not all new varactors are surface mount parts, so you have to solder them in on the foil side of the board.
