Hunter3141
Hello, first post here, thanks for reading.
I was lucky enough to inherit a McIntosh MX-110 and 240 amp, it was checked out by an audio repair shop a few years ago before it was given to me, it was all fine. After about 2 months of use, 30 hours of play time or so, the right channel started to fade gradually, at first I thought it was just a knob was bumped or messed with (toddlers!) but it wasn't the case. Now on stereo there is no sound from the right channel but both channels work on mono or L to LR and LR to R works as well. I've stopped using it now to save it from further damage as I know nothing about vintage gear.
I finally had a chance to check over it today and powered it up all the tubes are lit and hot, and going through all the settings I realized it works on stereo through both channels if loud is to in, I never used loud in my normal listening. This is the same for all inputs. Also tried switching L&R output to amp and then the left channel was out.
So should I not use the unit? is it something obvious I missed or is a shop visit necessary? I live in Austin so there are a couple of good tube places around just trying to save money (toddler!) Thanks for reading this post and any response you can give me
Hunter3141
Hunter3141
