Vinylcafe
Linvin' the Dream
I am starting a rebuild of critical components of a Sony TAN-8550, and am looking for someone experienced to check in with, for some assumption checks.
This is hardly my first rebuild, but given the unobtanium nature of the VFETs, I want to assume nothing.
All the VD1221 diodes have been replaced.
Next will be all the electrolytics, including the double 10000uf cap, which right now two singles are on backorder from Mouser.
I am also replacing critical components for the bias supply side of both boards.
This includes bias Resistors R725/775 and R731/732 and R781/782.
Also the 220K trim pots RT 701and 751 will come out. I will set these to the same value as the pulls before I install them.
Also changing out Q713-716 and Q763-766, as the service manual states that failure of these transistors will cause V-FET failure.
I have managed to get authentic Sony transistors as replacements
The service manual also has a procedure whereby you disconnect power to the V-FETs and measure voltage across R737 and 787 to make sure it is in the correct range, before applying power to the V-FETs.
It says to disconnect the brown and violet wires ... assuming they want brown and ORANGE, as the amp has no violet wires heading to those two boards.
The voltage I should be looking for after all the components have been replaced, is 38.8 - 43.8 for V-FETs with a ranking of 57.
Do I have this right, and are there any other critical components I need to replace
Are there any hidden dangers not documented in the service manual along the way
Any help much appreciated.
