rlisin
Quad 4 life
So here's the thing:
I got myself this INKEL set:
http://www.audiokarma.org/forums/showthread.php?t=581328
Having fixed some issues it had, I listened to it a bit and decided I liked the power amp, pre - not so much. Firstly, compared to other preamps I have it sounds a bit veiled, with mids recessed. Secondly, I hate the push button volume control, it's a real pain in the butt to set low volume just right on this thing.
So I went on a hunt for a nice ~1980 silver pre with a headphone socket (Inkel power amp doesn't have one and that was actually one thing I did like about the Inkel pre). I got a hk 725 that has pretty much everything I wanted, plus nice specs and some cool features like resistor-based tone controls.
Some more info here: http://www.thevintageknob.org/harman_kardon-hk725.html
It was sold as 'works fine, front panel needs some more cleaning'. Yeah, right. Only the second bit was true.
So, one channel was silent to begin with, but cleaning the output relay took care of that. The issues that remain:
- R channel has significantly (some 30%) less gain than L channel. I have to turn balance knob two bars to the right to get equal levels.
- Tone controls work fine on the quieter R channel. They have much less effect (but not zero effect, each button works and changes sound a bit) on the louder L channel.
- With tone control off, the louder L channel has a different tonal balance than the quieter R channel: it is brighter, with less bass. Going by ear, I would say that the quieter R channel is the one that sounds like it should.
It seems that the quieter R channel is working correctly and the problem is in the L channel. Neither channel is distorted.
I checked loudness and hi/low filters, they affect each channel, so apparently not the case of filter switch with bad contacts. I cleaned volume and balance pots just in case, no change. Obviously I flipped all cables between channels, etc. The problem is in the preamp. It's not the relay that was dirty, the issue is also present on headphones, which don't go through the relay. Basically it looks like there's a bug down the signal path that will not be remedied by simple cleaning. For me this probably means a trip to a tech, my soldering skills are not good enough to extensively work on this thing.
I am curious though, what could cause this symptoms (apart from things I've already checked)? On the off chance I could fix it myself
The thing is, I was willing to pay what I did for this pre, but with the issues it has, I'm not sure if I will like the sound, and I can't really A/B it with the pre it was supposed to replace. I need to decide whether it's worth the bother of getting it repaired or not.
So, do you guys know this pre? Is it as good as Harman advertised? Get it repaired or try to return it?
