What took so long, you were going to look into this a couple hours ago when I read your post about the CA tt with MC?
Yes, Sensitivity is 100µV or 0.1mV and that will handle all MC cartridges of that output level and higher (HOMC would use the MM setting). Even the VLOMC Ortofon cartridges, 70µV (0.07mV) would be usable, just needing more crank on the volume control and maybe not being able to play the really quiet parts loud. That MC puts out about .44mV so it will be just fine with that phono in MC position.
