In the 90's Altec made an analyzer that would tell you which anomalies in frequency response you could correct and which ones you couldn't with 1/3, 1/6, and parametric EQ's. . How by measuring the phase properties of the direct signal from the speaker. It took into account the characteristics of the filter of the equalizer and the phase or time distortions of the speaker. You adjusted the filters to smooth the response and at the same time corrected for the correctable deficiencies of the speaker. But if the speakers had complex crossovers and impedance correcting networks, then odds were the whole thing would go tilt. Anomalies narrower than a 1/6th octave were uncorrectable and if standing waves were a source of inconsistency they were uncorrectable too. So the room had to be well built with some thought and the speakers should have been tri-amped or bi-amped with external electronic crossovers with minimum phase filters for the system to work. Remember you can't equalize the reverberant field of a room. Your best compromise is to correct the system at Dc, critical distance, which is where the reverberant field and the direct field are equal. If you try to EQ your system at your seating location and you are in the reverberant field then the direct sound that arrives to your ear first will not sound natural. And people with point source speakers the Dc can be very short, under 4 to 6 ft. from the speaker, while the line arrays from the XRT 30, XR =290, XRT1k, XRT2k can approach the length of a soft room room.
