srivats
So my friend picked up a used Yamaha M2 for a decent price, and today I went to check it out and listen. This is the first time I'm seeing one in person and it's a monster! Insanely heavy and looks very industrial. I was surprised that the manual says this amp is rated to run only 8ohm speakers or above. What limits this amp's rating for low impedance speakers? The power supply looks well built .. I was hoping to find something similar since I am on the hunt for vintage infinity speakers, but maybe I have to look at M-xx models.
Before I rant on, here is the actual problem...
We noticed that the left and the right speakers don't have the same volume levels when the input attenuator in the back are set to the same values. We had to bump up the weaker channel by nearly one number (one channel at 1 and other at about 2) before the speakers sound matched to our ears. We systematically ruled out speakers, cables and preamp/sources as the cause. Both speaker A and speaker B outputs show this symptom, and the mismatch moves when the speaker wires are interchanged.
What could be causing this? My friend did not thoroughly test it before buying, but he says he did not discern a difference at the sellers place. Perhaps the volume levels were high enough. He has the option of returning, but if the fix is not too involved, we can try .. Both of us have some experience but not on a power amp.
(Sent from my mobile, please pardon my spelling)
