pdm4606
My C-50 has a trans that blew a few years ago. The primary is internally protected with an internal fuse and that went. I managed to pick the windings until I found an appropriate winding to energize and it works fine.
However, it sucks. The trans. has so many added wires and cable ties that it sticks up above the top surface making the replacement of the stock metal cover impossible. I will not mess with the setup as in is now.
I am looking for a replacement trans and am searching toroidals.
Does anyone have any input on the correct size(32V-C-32V) with the center tap setup as the original is?
Would a torroid work?
Or does anyone have any suggestions for a standard trans as a replacement?
Or does anyone have an old C-50 trans to replace?
Paul
Paul
