I use these on the back of my 1979 Cornwalls so I can use banana plugs in a horizontal or vertical position. http://www.ebay.com/itm/4pcs-Banana...=100011&prg=10283&rk=1&rkt=10&sd=181456528174
Yes, ideal. Exactly what you need for your wishes. Does the job perfectly. And easily.
Louis, do you think these would work with pins, such as I'm using with my '80 La Scala? Monster Cable, bought in the early '90's, when Klipsch dealers were pushing them; they never turned green & are still working.
I sent Louis the info on that eBay seller chanler.young; BUT, can't take credit, as I "borrowed" that info from some gentleman on the Klipsch Forums, LoL.
I just tinned the wire ends and scewed them on the binding post with no problem.....
In my experience even total purists are not put off by upgraded input terminals, especially if the originals are unusable (or a total PITA to use) with modern wire.
