Wrap up
a few things cropped up after I wrote the last post. The arm was sliding across the record and attempting to adjust the balance of the arm was fruitless since it was free floating and wanting to float back to its arm rest, regardless of where I set the tone arm. I ended up replacing the two vertical driver transistors and the op amp. I used NTE transistors that were complementary to each other. I suspect that you would have to adjust the vertical pot after the replacement. With the replacements, the arm did not drift towards the arm rest and I could adjust the arm .
Listening to the music, I noticed that the music was not as detailed and muddy and Intermittent humming was coming from my setup in the phono mode and I traced it back to the left channel of the turntable interconnect cable. I reheated the solder joints and now the sound is beautiful. A person commented on another post that his friend was saying it sounded like a CD. Well, that statement is pretty close. I have listening to my turntable now and my digital media is taking a vacation.The previous owner installed an Ortofon VMS20E MkII cartridge. Which to me is a wonderful match.
The transparency and imaging and is very good and the soundstage is wide.
Every record I spin, just sounds so good, I am listening to Julio Igesias and he sounds live, very nice transparency.
I do have a question, my arm balance weight is near the end of the tonearm arm to be balance, is that normal? It was previously half way down the arm sleeve.
My system
Denon PMA -757
Celestion ditton 300 speakers.
Sony dvp-s7700
