fucanay
I've been running a Philips 212 with a Grado ZF-3 cart for about a year and I'm thinking upgrade. It sounds ok, though I have had some dropout issues from time to time. The speed is rock solid and it seems pretty forgiving with sketchy quality records (scratches and slight warps).
But it also feels a little on the flimsy side overall and I've heard that adding a better cart won't do much on this table.
So I've been looking around and seeing what is out there and what is pleasing to look at. But I have zero idea how a lot of them will compare in terms of sound, cart choice, reliability, etc.
My only requirements other than better performance are:
1. Auto stop, preferably lift and return also.
2. Nothing plastic, preferably a wood top like a PL-530, but wood base is ok as well.
3. Not cheap feeling, I'd like some weight and it to feel good to use. (Is this just plain silly?)
I'm thinking used and probably from the 70's. I have no preference for belt drive or direct drive as long as it's quiet while I listen at low volume. I want to stay under $600, but need to sell off some guitar gear before I can afford that, so I have some time for opinions and research.
Edit: Oh yeah. I listen to mostly rock and acoustic music. I'll be using an HK 730 receiver and KLH 6 and 17 Speakers.
Thoughts?
Thoughts?
