Hi,
$545.00 on ebay. I contemplated it too but it is a fair bit of work. None the less something fun to do if time and money are available to restore it.
First obvious things that stands out.
1) Earlier repair could not even get a complementary pair as replacements (2SA1117 odd ball), that is not such a good idea = you can be guaranteed that the pairs are not sharing the load current very well.
2) Big ecaps toast = more big $ to possibly spend.
Hopefully your "partial carcass of a 1250" will serve you well, as a spares unit
Good luck
Rick
I think I have a 2SB600 laying around if you want it.
Hi,
Epcos is a well known mfg, so I can not see any issues with a computer grade ecap. 100V caps are not necessary, 80V caps are a bit cheaper. Can not be 100% sure without looking up the specs, but need the exact part number for that. Obvious things are, the mechanical fit, the correct diameter is most important, the rest, well are probably fine.
Another option, is to stick with the 80V rating and bump the capacity to the next higher increment, 27K or 33K, but there are many options.
Cheers
Rick
