zebulon1 said:
From Mark 2012:
Protection Circuit Assembly (AWM-062), total rebuild list
AWM-062: C1: .22uF 10v CSSA: 667-ECQ-V1H224JL2 .22uF 50v o/c sense must be stacked film, not little sky blue sanyo can electrolytic
AWM-062: C2: .22uF 10v CSSA: 667-ECQ-V1H224JL2 .22uF 50v o/c sense must be stacked film, not little sky blue sanyo can electrolytic
AWM-062: C3: 330uF 6.8v CEA: 647-UPW1A331MPD 330uF 10v 1/2 of make polarity free capacitor
AWM-062: C4: 330uF 6.8v CEA: 647-UPW1A331MPD 330uF 10v other half of make polarity free capacitor
AWM-062: C5: 4.7uF 25v CEA: 647-UPW1V4R7MDD 4.7uF 35v ac power sense
AWM-062: C6: 100uF 16v CEA: 647-UPW1V101MPD 100uF 35v timing capacitor
AWM-062: Q1-Q2 2SC869-C 512-KSC1845EBU (ln)to-92 ecb 120v .05a .5w 100mhz 150-800hfe $0.05 ea o/c sense
AWM-062: Q6 SSC945-Q 512-KSD1616ALBU to-92 ecb x60v 1a 0.75w 160mhz 135-400hfe $0.09 timing capacitor charge dump to turn off
AWM-062: Q7 2SC1384-R 512-KSC2690AYS to-126 ecb 120/a160 1.2a 20w 155mhz 35-320hfe $0.40 relay drive transistor
don't forget to add the 512-1n4004 flyback diode to pins 9 (anode) and 10(cathode).
That list is a little out of date, Q1 and 2 replacement should be a 512-KSC1845FTA, Q6 replacement should be a 512-KSC2383YTA. The rest looks okay. Also, I recommend rebuilding the power supply transistors as well, a couple of them are under powered for what they are handling, namely Q5. Q7 is also a little under powered, but not as bad. This is my updated SX-950 power supply list, I've changed the bigger caps to snap-ins for a better fit and look:
Power Supply Board (AWR-101)
AWR-101: C10: 470uF 80v ACH-038 (Snap-in): 667-ECO-S1KP681BA 680uF 80v
AWR-101: C11: 470uF 80v ACH-038 (Snap-in): 667-ECO-S1KP681BA 680uF 80v
AWR-101: C12: 2200uF 35v ACH-039 (Snap-in): 667-ECO-S1HA222BA 2200uF 35v
AWR-101: C13: 1000uF 25v CEA: 647-UPW1V102MHD 1000uF 35v
AWR-101: C14: 220uF 10v CEA: 647-UPW1C221MPD 220uF 16v
AWR-101: C15: 470uF 63v CEA: 647-UPW2A471MHD 470uF 100v
AWR-101: C16: 47uF 16v CEA: 647-UPW1E470MDD 47uF 25v
AWR-101: C18: 47uF 50v CEA: 647-UPW1J470MPD 47uF 63v
AWR-101: C19: 47uF 35v CEA: 647-UPW1H470MED 47uF 50v
AWR-101: C20: 100uF 63v CEA: 647-UPW2A101MHD 100uF 100v
AWR-101: C21: 47uF 16v CEA: 647-UPW1E470MDD 47uF 25v
AWR-101: C23: 100uF 35v CEA: 647-UPW1H101MPD 100uF 50v
AWR-101: Q1: 2SD313: 863-MJE15032G
AWR-101: Q2: 2SB507: 863-MJE15033G
AWR-101: Q3: 2SC1318: 512-KSC2383YTA
AWR-101: Q4: 2SA720: 512-KSA1013YBU
AWR-101: Q5: 2SC1318: 512-KSC2690AYS
AWR-101: Q6: 2SA720: 512-KSA1013YBU
AWR-101: Q7: 2SC1318: 512-KSC2383YTA
AWR-101: Q8: 2SD313: 863-MJE15032G
AWR-101: Q9: 2SD313: 863-MJE15032G
AWR-101: Q10: 2SC869: 512-KSC2383YTA
For the AWH-059 trim pots:
VR1: 1K ohm multi offset: 652-3296P-1-102LF 1K ohm 25 turn
VR2: 1K ohm multi offset: 652-3296P-1-102LF 1K ohm 25 turn
VR3: 100 ohm single bias: 652-3386H-1-101LF 100 ohm single turn
VR4: 100 ohm single bias: 652-3386H-1-101LF 100 ohm single turn
