I'm getting a bit confused as well. How about a summary for us Mark.
Can you give us a breakdown on which amps, preamps, etc., you are ultimately planning to match with which speakers. If not in this thread maybe a separate one. You're moving to fast for me man!
cubdog
OK, I can do that. I was trying to avoid too much brevity, hence the confusion, but here goes. I will preface my comments by saying that I can sort of equate building a hi-fi system with building a rock crawler Jeep. You build a Jeep according to the size tires you want to run. I think you can apply that when building a system. I will build by virtue of the room dimensions, type, etc. The wife and I have decided to build a system for the den. At the same time, I am still working on my small office system.
The small office gets the low power/high efficiency gear. Dennis Had amp, preamp, Great Horned Heils, Sim DAC, SBT, and the Basis TT. This room is a continual, ongoing project.
The den gets whatever I can come up with. I am admittedly all over the map on this one. I really want to get some floor standers that are around 90 db or better and or easy to drive. I want simplicity; amp/preamp, speakers and a very nice CDP. That's it. I really liked the Melody mono's and at 70 watts a side, they had the grunt to power most speakers. They were just out of range. I have no aversion to clean used gear, either. New is cool too. I may get a chance to audition that LM 218IA next weekend. I want to see if it has the power I need. We'll see. The den is rectangular, with six windows on two walls and a huge built in bookshelf that spans nearly the entire opposite wall. It is a very relaxing room with a great view of our wooded back lot, but it poses a challenge so I have to get this right. I do regret not buying the used Spendor's I saw advertised. They were the older model similar to ArtK 's new ones. They would have made a great start. I do want a quality system in this room. I am also in no hurry; I want to get this right the first time.
Kegger is building me an amp also. I am getting that one...cause I can
I hope that explains my intent a little better. Winter is my audio hobby season.
