unchained527
Member
Hello. I'm using a Technics SL-B3 these days. The problem I have had for quite some time is that, perhaps 40% of the time, when the stylus meets the record over the run in groove, it will slide quickly into the song, sometimes up to 2 or 3 seconds in. My TT has done this for a while. I thought maybe it was the cart, but at one point I had the cart replaced and re-set-up, and it still does it. I've checked to make sure that the plinth is level, more than once. It does it whether I set the tonearm down manually, using the automatic function, or using the lever on the TT.
This can't be a normal occurrence, can it? I figure it can't possibly be good for my records or my stylus. Any help is appreciated!
