tube tied
Member
First off, I want to thank ozmoid for his great set of threads on the rebuild of his 2ax's! And redpackman's, Snow's, and Thom's threads, too.
I picked these up for the cabinets. Super-inexpensive, so I took the sellers word that they were horrible/scratchy sounding and presumed they were "dead". Took the grills off yesterday (not easy with 15+ staples and glue and tight fit) and found both woofers were separated from the cast baskets. Pulled the old rheostats and found they were loaded with corrosion. I was out nothing so I cleaned the rheostats to the best of my understanding and tried again. BOOM! Tweeters are both working. I glued the surrounds down and went to bed. (That process, along with getting the laundry through the washer/drier, took 5 or 6 records…written, it sounds like nothing, yet that was a real project for me.)
Fired them up and am listening now and have a pile of question:
1) The woofers have a scratchiness (like a radio station not tuned in well) that for the most part goes away with a little touch on the "rubber" ring on the cone. Any idea on what that is scratchiness is telling me? If this helps, I initially had them tweeters down (see comment e, and I had them on some other speaker cabs so the tweets were at ear level that way). I flipped them over (tweets up), and that seems to have helped get rid of some of the scratchy noise. ???
2) With the little bit of research I have done, I am not convinced there is an absolute way to preserve the surround and/or the "rubber" ring. Is there???
3) The tweeters are working and sound pretty good considering they are as old as I am!!! Is there any reason to pull them out?
4) You can see the cap that is in them (obviously original, correct?). Are they the oil filled ones I have read about that may not require replacing? And how do I test them without taking them out?
5) I am a little embarrassed to ask, but this is how we learn… Was I wrong using Elmer's white glue to put the surround back down?
Comments:
a) I just dropped the needle on the Who's "Who's Next" and man, the "performance" is deep and wide…at times like I could reach up and grab parts of the sound right by my ears!!! I know that sounded weird, yet even as rough as they are, they have a special "life" about them.
b) There was no wire mesh around the woofer's baskets like I've seen in other threads' pictures. What was there was a sheet of thin, felt'ish packing-type stuff tucked all the way around all the chunks of insulation with the wires ran right through the middle of it. Is that weird or help date them in any way?
c) The heads of the philip's recess bolts holding the tweeter in have been peened. Is that to keep me out? Were they expected to last forever? [From other threads and forums I have read, that does NOT appear to be fact. ]
d) One of the jumpers has round, washer-type ends and the other has slot types. Considering the serial numbers are X 04926 & X 04905, I was surprised to see any differences.
e) There are 5 felt pads on the tweeter end of the cabinets. Are those original? In another way, were these designed to be set up with the tweeters by the floor???
I am looking forward to everyone's input. Thanks in advance.
Comments:
