Maybe I should just give it a go....
Another Q. Can 1 plate amp be used for the 2 woofers at the same time?
Thanks PG...I might need to ask you how later.
Since the OLA has the reputation for good bass, I'd think they'd make good DB apparatus.
It's not difficult. Here's a typical plate amp mounted in a frame with it's red and black speaker wires connected to two binding posts.
I just double up the speaker wires ( twisting them together ) from each binding posts and connect one + and one - to each woofer.
If the woofers are 8 ohms then this connection will yield 4 ohms which plate amps love.
The RCA line in inputs on the top of the plate amp can be connected directly to a source or a preamp. If connected directly to a source then the plate amp's line out can connect directly to the main amp as the signal is a pass through.
Plate amps have a power cord plug-in on top.
I've used my Utility 3 Large Advents for subs for a couple of years now. Just put your sub out into the CD in of your spare 100 watt per channel AVR. Put the spare AVR on direct two-channel mode. Turn your Advents on their sides and use them as subs / speaker stands.
It works great and don't let anyone tell you that it doesn't
Cheers,
Wayne
p.s. you'll need an one into two Y splitter cable from your sub out so you can go into left & right channels of your CD or Aux. input on your spare AVR.
I treat plate amps like any other amp and they reside in my rack. Their volume controls are always within arm's reach.
I wouldn't like having to control subs/woofers and mains with the same volume control.
You will get better bass performance if you connect the sub amp to the speaker terminals, rather than directly to the woofer.
The only thing in the crossover that low frequency signals see is the 1.6mH inductor in series with the woofer which acts like a low pass filter. See here: http://baselaudiolab.com/ADVENT_LA_XO.html
If I naively model the woofer as an 8Ω resistor I get a 3dB cuttoff freq of around 800Hz. In other words, if you connect an amp directly to the woofer, it will give you more mids. It all depends on the x-over in your plate-amp, which is probably low enough that it won't matter.
Also the high pass filter in the tweeter's x-over will block the low frequencies.
Point being, there's no need to do surgery. Just hook it up and see how it sounds.
