danielphanto
Member
I have had an sa-7800 and a tx-7800 for a month or so now, haven't done anything except deoxy the switches, pots and connectors.
Haven't had a problem until today when I hooked up an old turntable and the volume pot had to be turned to Noon to hear a thin reedy sound.
I tested out another turntable and same result.
These are not mc cartridges or anything fancy (Technics sl-q2 with stanton cartridge and a Denon 80's model as far as I can tell basic MM carts)
So I have downloaded the service manual and although I can't print out that huge schematic--I have looked through the manual briefly but didn't see anything regarding testing out the phono section--did I miss something?
I did an exploratory this afternoon and got the phono board disconnected from the front chassis and with all the tight wires that are wirewrapped in several different directions keeping it pretty tightly in its current position and I couldn't get a good look at the component side.
It looks like there are several test points on the circuit boards but the only test voltages I see are for the bias at the testpoints down next to the heatsink.
What would your first step? Re-capping? I saw something about leaky caps in certain areas reducing the gain of the phono preamp. Don't want to mess up anything that's already working fine.
sorry for long winded run-on sentences
thanks
Daniel
thanks
Daniel
