captouch
Addicted Member
I've seen pictures of people stripping the vinyl off their Yamaha receiver/integrated cases and just refinishing the wood that's already there (plywood?). It looks good enough for me and the fallback is to put on real veneer if the underlying wood looks bad.
But I'm wondering about the best way to remove the existing vinyl. Does it peel off in very small, annoying pieces, or once you get it started, does it come off mostly in one piece? Is heat needed to facilitate things?
If small pieces bit by bit, maybe a sander to just sand it off?
Thanks.
Thanks.
