After reading David Kan's February 2007 6moons review of the Trends Audio TA-10 amp at http://www.6moons.com/audioreviews/trends/ta10.html I decided I'd like to experiment with battery power to see for myself if it can actually improve the sound quality of my soon to arrive TA-10.1 as claimed. Not that it will necessarily need improving for the use I'll be putting it to, but I'm curious. Kan mentioned he was using a Xantrex Powerpack 300 EP for his tests. This battery pack was designed primarily for automobile use and incorporates a compressor pump and hose for inflating tires, booster cables to jump-start your engine as well as a built-in flashlight. That's all well and good, but I have no use for a compressor pump, booster cables or any more flashlights, and in the room where my TA-10.1 amp will be used space is at a premium (part of the reason I bought the mini amp in the first place.) Can someone recommend a more compact, bare bones battery pack that would work well with the likes of a TA-10.1 amp?
I realize hooking things up to any old rechargeable 12 volt battery would do the job, but there's one caveat Kan states in his review:
"The Tripath T-2024 chip has an absolute working parameter of 8.5 to 16 volts DC - either too much or not enough is bad for the chip."
The Xantrex Powerpack 300 EP has an auto-shut-off feature that sets off a low-battery alarm at 11 volts and shuts down when the voltage drops to 10.5 volts; a nice safeguard for the Tripath chip -- the sort of safeguard I'd like my bare bones battery unit to have, too.
Any recommendations anyone could make would be most appreciated.
